1950 refrigerator....Yeah right!!!!
People are so funny sometimes when it comes to selling things. They put "VERY GOOD CONDITION", yet there's that oh so endearing term "DOES NOT CURRENTLY RUN" and "NEEDS AN ELECTRIC CORD".
I'd say that seller has some explaining to do.
That's a later unit on top of an early cabinet.
Usually when I'm cruising the listings for old Telechron clocks, if the cord has been cut the rotor (motor) is likely shot.  Not a big gamble since the rotors are usually easily revived.
A monitor top that weighs in the neighborhood of 500 pounds and uses sulfur dioxide is a whole 'nother story.
Yes Sulphur Dioxide stinks,is toxic-but is a good and EFFICIENT refrigerant.-And it was inexpensive.Ammonia is a good refrigerant,too it is toxic-but VERY effective esp for very low below freezing applications-Ice cream makers still like it.Ice houses that made block ice-still traces of them today-liked ammonia.It was used along with brine.The ammonia evaporator coils were used in the brine-the container of what you wanted to freeze was put in the brine.This gave isolation in case of ammonia leaks.Esp for food or ice to be used with food refrigeration.Of course toxic refrigerants CANNOT be used for human comfort refrigeration directly becuase of their toxicity.Food contamination with the older Sulphur Dioxide fridges was rare-but leaks were serious-when sulphur dioxide contacts air-turns to sulphuric acid vapor-TOXIC-burns lungs,eye,skin.and reaction of it with some materials could cause a fire or explosion.
That was my suggestion: Put the real decade that the appliance is...
(In this case, in parenthesis; the seller there doesn't "seem<span data-ft="{"tn":"K"}" data-reactid=".2z.1:3:1:$comment10152557808611125_10152557882181125:0.0.$right.0.$left.0.0.1:$comment-body"><span class="UFICommentBody" data-reactid=".2z.1:3:1:$comment10152557808611125_10152557882181125:0.0.$right.0.$left.0.0.1:$comment-body.0"><span data-reactid=".2z.1:3:1:$comment10152557808611125_10152557882181125:0.0.$right.0.$left.0.0.1:$comment-body.0.$end:0:$0:0"> to</span></span></span>" know...)
<span data-ft="{"tn":"K"}" data-reactid=".2z.1:3:1:$comment10152557808611125_10152557882181125:0.0.$right.0.$left.0.0.1:$comment-body"><span class="UFICommentBody" data-reactid=".2z.1:3:1:$comment10152557808611125_10152557882181125:0.0.$right.0.$left.0.0.1:$comment-body.0"><span data-reactid=".2z.1:3:1:$comment10152557808611125_10152557882181125:0.0.$right.0.$left.0.0.1:$comment-body.0.$end:0:$0:0">-- </span></span></span>Dave
That's a mid 1930's CK 35 top on a late 1920's cabinet. It likely runs just fine. The only thing that usually goes bad is the relay.
SO2 is nasty, but you can deal with it. If it leaked, get out of the house. You wouldn't be able to stand being in there anyway! If I had one and didn't have any legs, I might be worried a little. Treat them with respect and don't defrost with a sharp object and it's all fine.
