Cool 57 Kenmore Automatic
Welcome to the site Justin
The 57 is a cool find, it is always fun to find the more basic models as well as the TOL machines we all seem to love.
This 24" wide machine was popular for its slightly lower price and smaller size which allowed it to fit in kitchens and apartments where the full sized machines would not fit. Very few 24" machines had the Suds-Saver option, again because there usually was no laundry tub since the machine was purchased to fit in a smaller space.
This washer could be turned into a fairly reliable machine, but certainly needs a good going over if you expect it to work properly and last very long. It would be easy to add a Suds-Saver which would make it work well if you also use your WWs much. The water capacity of the 24" washers is 16 gallons and they were rated for 8 pound loads of cotton fabrics.
Since it won't run try loosing the motor mount at the base plate and get the belt off the pulleys, then you can see if the motor is free to turn etc, the water pump is the most likley item to size and of course the belt may just be rusted to the pulleys.
I have any parts you might need to rebuild this washer, a few years ago I rebuilt several BD WPs for myself and others and I need to schedule another rebuilding session as I have several other machines I want to do, when I do this you might want to bring this one up and do it at the same time. Get in touch some time for details.
