1953 GE Wringer Washer...Should I?
macboy91si
Jan 10, 2009
1,296
Frankfort, KY
I have the chance to obtain a 1953 GE Wringer Washer in relatively good cosmetic condition. Has a pump, but it will need some minor paint and bits to be really nice. Unsure of running order, but was told that the agitator works when powered on. It's a neat looking machine, has a timer and pump, not a Filter-Flo wringer though. They're asking $60 locally for it, I couldn't snap a pic, but I found an ad for it online which is damn near exact. One of the shields has come off of the wringer, but is still there, and the manufacture date is stamped as Sept. 1953. Anyone know anything about these? Things to look for?
-Tim
Hi. This was my parents first washer. I have used it as I got older. Had it until 1962, then they got their first automatic. It was a great washer. Large tub, and washed the clothes well, the wringer also worked well. I cannot remember what went on it. We were given an old Thor wringer to use until we moved and got the automatic. I used it starting in 1960. Grab it if you can. Nice to see it around again.
Ray
Neat machine!
My folks also had a machine similar to this one - it was our 'backup' machine for extra large laundry days! I also had a similar Hotpoint version and I noticed three issues common to these machines: 1 - the pump friction drive wheel can wear out - I would bet that the part is still available out there somewhere though! 2 - the rubber drain chamber is prone to leaks - the part was still available from GE in the early 70's, but now... you can fix any leaks by coating the chamber with a high-heat epoxy (used in auto repairs and should be available at a serious auto parts store) 3 - the timers were a bit unreliable. And on that note, I did manage to keep the timer from the Hotpoint machine I used to have before scrapping it because of a pump drive wheel failure (I regret that...) so if you do get this machine and you need one, let me know!!
Good luck - $60 seems pretty reasonable to me!
My grandfather in Mississippi had an old GE wringer washer in his wash house, but it looked nothing like the one pictured. It had legs instead of a full skirt, and no control levers on the front. I think you just plugged it in to make it go. I guess it must have been an older model, maybe from the '40s. I remember a red GE logo on it.
