1955? ABC Dryer - Greenvile, MI
Nice dryer, indeed!  I cling to the hope that an electric one will surface someday...
Mark, good one on the Jackson 5 reference!!
Mark Harman
Has one similar to this, I have seen it in use and it really works well, the elements are on top and the filter is a large slide in thing at the bottom.
Greenville
is where the Gibson plant was. AB Electrolux closed it in 2004.
Not even the Meijer store in Greenville stayed open long afterward.
A friends father is buried there in the cemetery next to a lake.
From the link above
"ABC continued to improve its products and
manufacturing methods with new processes , and many innovations. It added electrically-driven washers: progressed from the "dolly
type" washers to the cylinder, the oscillator, the vacuum cup, and the reversing agitator types."
Anybody ever seen the "vacuum cup washer?" Having a hard time picturing that.
vacuum cup washer
We have covered them before here in the group.
ABC, Easy, Hurley/Thor, and many others in late 1800's through early parts of the last century designed and produced washing machines that used the "vacuum cup" method. Indeed until two basic types won out (cylinder/h-axis or tub with central beater), there were many different types of washing machines all touting supposed superiority.
Principle behind these machines was taken from the hand held "vacuum" washers:
Basically the downward push forces water/suds through the wash. On the up stroke a slight suction is created that was supposed to (in theory) "pull" dirt/muck out of clothing.
Cannot say how well the powered machines work, but my hand held "rapid washer" works a treat.
If you watch the washing action from these devices you can see where Frigidaire/GM came up with their "jet action" or "pulsating" agitation. Instead of moving clothes through water you force powerful currents of water down though the wash which force dirt/muck out.
Ohh Yes!
By the eve of WWI and certainly after WWII you notice all these "quirky" washing machines had long vanished. Yes, you had top loaders offering a vast and interesting methods of agitation but one thing became clear; American women wanted fully automatic washing machines that required little involvement.
Washing is done in two basic ways; you shift the water, or you shift the wash.
Few if any of those early washers had pumps and or filled automatically. Thus you still had to "shift water" because somehow tubs had to be filled and drained. The real labor savings came from fact machines (in theory) did the agitation. But that still left often wet floors, use of wringers (and or later spin dryers), buckets, hoses, etc....
You notice all these early machines were simply semi-automatic washers. All required some degree of user interaction and that meant having to hang around on wash day. You *could* start the thing and go off and do something else, but had to return sooner or later.
What is interesting is how many of those old "vacuum cup" washers are still out there. Mostly from Easy but have seen others.
Jackson 5 Reference
I am so glad someone got a kick or laugh out of my Jackson 5 comment.I try so hard to make people laugh here and most often my strange humor draws a flat line and crickets.Even the crickets aren't laughing. I was beginning to wonder if the club is made of strictly humorless dullards. The last time I got a reaction was several years ago when I referred to the TLC channel as The Loser Channel.
