1955 GE COMBO Restoration
GE Combo Drying System
This and All GE Combos has two heaters, a smaller 1200 watt element and a larger 2800 watt element, the smaller 1200W one is on the top left and is the most visible one in Jon's pictures. Both are used for normal drying at the start of the dry cycle and with a full rated load of ten pounds of cotton towels [ spun at 210 RPMs ] all 4000Ws of heat will be on constantly for at least 45 minutes, once the thromostat trips [ about 280 degrees F ] and the timer starts moving it will switch off the 1200w element and the 2800W element will heat the load again to 280F, this phase will take another 15 minutes or more.
All the while 1/2 gallon of cold water is flowing down on the right inside of the outer tub , which not only condenses all the water being evaporated out of the clothing, but also carries at least 80% of the heat away and all of the lint, dust and other grit right down the drain.
The drying temperature is adjustable and can be turned down to as low as 180F for drying delicate items and when the temperature is set for delicate clothing the smaller 1200W element is not used at all.
GE combos were very effective dryers and they had to be to dry clothing that was close to being dripping wet. Tom and I found that if a load was re-spun in even a WP BD TL washer the drying time was cut in 1/2.
Go figure... my combo has two heaters too but one is 750W and the other 680W! In the delicate cycle only the 750W one is operative...
but the load is spun MUCH faster! :D
(still it needs 80 minutes for 6 lbs of clothing!)
Update
I worked on the Combo yesterday and for the first time I got it to run on the dry cycle WITHOUT the timer motor engaged !! So big progress on that front. Now it seems to be narrowed down to one glitchy little problem, on dry sometimes I get 220V out of the control thermostat and sometimes I don't. If I can correct this then I can reassemble and try a virgin load!!
I started this thread what? back in ......November??
I gotta get this machine outta the lab, I got more stuff com in'!
Great news! Is it possible that the thermostat is tripping too soon due to an empty tub load? That wash tub gets plenty hot when both calrods go into 'speed-broil' mode!
So
after yesterday's testing she has a small punch list.
1) Aim water inlet nozzles for fill & condenser
2) Debug timer connections for timer motor cycle
3) Recheck short to cabinet- I think that is because the entire guts got drenched yesterday by the inlet nozzles spraying water all down the insides.
A small punch list after all the work she's had don'tcha think?
Sounds pretty minor Jon!! Can't wait to see the next round of progress!!
I've created some pretty interesting grounding situations with leaky machines... THAT may explain a lot... LOL
If you have any issues with the fill flume or funnel, let me know; I have the ones from the early 56 combo that got parted out last year.
Is the timer not getting power at a specific phase of the cycle? If so, that can be 'normal' - trust me!!
Great Job Jon!
What a beautiful machine!
Is this the only working 1955 Combo known of?
Thanks Paul
I'll keep the spares in mind but the funnels are brass , I think the problem is me, I removed the entire valve assembly to clean and update and didn't think about how I put it back in place because the funnels are so huge on this machine. OOPS!
Brent as far as I know this is the only known example of a 1955 GE Combo , as to working well I leave that up to you!
I have run the entire cycle and this may interest some of you- there are 5 rinses! But there are no spins between rinses. AND the 5th rinse is with HOT water !!! I would guess to prepare the clothes for the broiler-dry cycle to follow. After the 5th rinse the machine goes into high speed spin - 225 RPMS LOL  for a time the drops to a tumble and then if I remember a short spin again before starting dry.
Incredible Job
What a great job, Jon. The machine looks wonderful, and I love all the intricacies of this type of appliance. Combo's were truly the engineering marvel of the laundry appliance world! Thanks for sharing all the photos and knowledge. Congrats on your success with it, and here's to many "broiled dry" loads! :)
