1956 Duomatic
Good luck with the magic heater. You may want to try bending a hot tub heater element. The wattage is the same and will work under water and they are cheep as dirt at $15 on line! The boot is grate! No leaks from it at all the only thing is the door doesn't want to close with it but that is a little adjustment.
I got the itch to do some more work done the other day. After I was done I washed/dried 4 loads yesterday. Now the bad, I had a feeling this was going to be a problem and I was right. The pump shaft seal is leaking when draining. But on the good side the cheap heating elements work grate! It takes about 20 to 30 min to dry a load. As for the pump shaft seal I can’t get the impeller off without heating it up real hot. Do you guys think I will damage anything by doing so? Or should I just put an electric pump in its place? I’m just afraid it would be really loud.
Anthony
