Thanks for the ideas... here's more info...
I do appreciate the ideas, keep them coming!
There is no added fan. The only thing I added was the Supco thermostat to attempt to regulate the temperature better. The automatic only turns on and off, and regulates the temperature "automatically," this lead to frozen food where it wasn't supposed to be, so I put in something I could adjust. There is no fan behind the freezer, It looked like there would be, so I took off the back compartment to check and see if it worked. There was only insulation. I think what you are looking at is the blue circular shade for the light bulb. I took this picture while defrosting so I wouldn't get the glare.
Both shelves are in there designed spots. The middle shelf is set to the higher spot to allow for taller foods on the bottom shelf. The picture is at a slight angle. Sorry about that.
The back of the fridge is approx. 3 inches from the back wall of the kitchen, there sadly isn't enough room to allow for the same distance on the sides.
I tried the temperature bulb in the fridge. On the warmest setting, food was freezing in the fridge. I put it up there to try to get it to cut off sooner. It's been a modest success, but still not perfect. Things are still freezing down below, but not as badly.
Thanks again for the ideas. I appreciate the feedback.
