1960s GE Time Capsule Kitchen
beefsquatch
Jan 21, 2019
10
Buffalo, NY
My wife and I have just moved into our 1960's time capsule house. The house is 98% as it was when built.
The kitchen had all top of the line GE appliances.
They were all in such good condition, we questioned if they ever even used any of it.
The only part that isn't work on the cooktop is the Sensi Temp burner.
And I'm having trouble finding much information about this particular system.
The model number is J P86X1GR serial number H XR00816
I tried dating the unit using the GE site, but 'XR' is listed.
I know that the sensor itself is bad because there is continuity across the two wires.
The biggest problem I have is finding the correct sensor.
I have the earlier sensor that is 10ohm with two white wires.
Does anyone have any leads on those older sensors or at least a part number to help in my search.
Any help would be greatly appreciated. We really want to keep this kitchen as it is.
Unfortunately, I can't help with your question as I also have sensi-temp issues with my stove. However, I'm in need of an older one with white wires, so I may be interested in your spare if you decide to sell.
Beautiful kitchen, by the way!
Jeannine
"We really want to keep this kitchen as it is."
That is such a refreshing thing to hear!
You may need to keep an eye out on ebay for a new sensitemp sensor.  I agree that it looks like that cook top was hardly used.  The original owner must have been a fastidious housekeeper!
Very cool intercom system.  Does it still work?  It looks like there's a chance it could be solid state.
If the dishwasher still works, you should go buy some Powerball tickets.
Best thing to do
is have the sensi temp switch changed to a infinite heat control, easy and inexpensive to do, the sensi temp was nice when it worked unfortunately it was trouble prone, that is a beautiful kitchen!
The dishwasher was not in working order unfortunately.
So we replaced it with a new Bosch unit that had the top control panel, had custom paint mixed to match the original and painted the door.
Then we took all the trim off the old GE and transferred it.
I've been looking for the Sensi Temp sensor. It's just hard to find not having the part number.
Before learning about the two different sensors, I ordered a later 17.5 ohm sensor.
While it did allow the burner to work, it didn't maintain the correct temp. I couldn't even get it to boil water.
So if anyone is in need of WB21X5207, I have one that is working order. It was brand new until I tried on my unit.
I'm not opposed to converting to an infinite heat control. Is there a specific one I should use over another?
Picture of the Bosch dishwasher
As for the intercom system, it does work but is in need of some serious maintenance.
It is a tube unit. The radio reception is week even though it has an antenna that reaches into the attic.
I’m sure a few of the tubes need replacing. It’s on my list for winter projects.
The house has intercoms in every room and two outside, front and rear doors.
Lovely Kitchen!!!!!Fix it up and USE it!!!!Like that NuTone intercom unit.You may have to use contact cleaner on the switches and see if that will help.The intercom looks like its in new condition!
Wow - love what you did with the dishwasher!
I'm not well-versed in the repairs of the GE sensi-temp surface units, but I have seen a few installations where an infinite-heat switch was substituted for the temperature-controlled unit.
The NuTone intercom is soooo cool!!
Regarding the sensitivity of the Nutone radio/intercom, it could be an issue with the B+ voltage being low due to an ageing selenium rectifier which can be replaced with a simple 1N4007 silicon diode and a dropping resistor. In an almost always on system like an intercom, a selenium wouldn't fare well. The output of the rectifier should be somewhere around 130-145 volts, much lower than that and the radio won't have all the reception and loudness it should. A Failing filter cap could have an effect on the B+ too, but you would likely hear quite a bit of hum as well. If those are both in order, then you can try substituting tubes.
