Looking for 1964 GE Americana Wiring Diagram/ Shop Manual.
whatsupdoc
Nov 20, 2025
3
We have a 1964 GE Ameriacana refrigerator that has seen daily use since new.
It recently stopped cooling and I am looking for any service information parts, wiring and or repair manual.
Thanks
Thanks
GE used to put a folded parts manual tucked inside the bottom front or rear.
Has the condenser coils and fan been cleaned of built up dust?
A model number and or pics would help the members here give advice.
Coils have been cleaned, the ones I can get to from the front by removing the bottom grill. Unit is at our second home and I need
to pull the refrigerator away from the wall but I cant seem to move it on my own so when I have help I will move it so I can get access to
the compressor and the tag with the model number on it.
Not my unit but the same one.
GE Americano, refrigerator, bottom, freezer models
These are wonderful refrigerators. I have two of them. There’s a copper tone one in the museum kitchen, and I’ve had a white one as my primary refrigerator in the mountain house for over 25 years.
What seems to be wrong with yours? Is it running at all?
Most common problems with these the fan motor for the refrigerator section sometimes dies, and you get no cooling in the upper part but the freezer may still work, there’s also a fan motor in the freezer, but they usually cool pretty well without this fan if it dies. There’s a fan motor to cool the compressor if that motor goes bad the compressor will overheat and it won’t run enough to do much cooling because it keeps cycling on the thermal overload to protect the compressor. There’s also two thermostats the one in the freezer section makes the whole thing run if that goes bad the thing will be dead except for the lights. There’s a defrost timer that could fail that normally will cause it to have a heavy buildup a frost in the back wall of the freezer and you’ll lose cooling in the refrigerator section 1st the freezer usually stays pretty cool under these conditions. And there’s a thermostat in the refrigerator section that controls the fan operation for the refrigerator if this thermostat dies the refrigerator won’t cool at all, but the freezer may still work.
The worst serious problem with these will sometimes have is the compressor loses capacity and everything runs properly, but it will barely maintain proper cooling temperatures especially the freezer will not be cold enough to do more than freeze a little bit of ice, but it won’t keep things solid.
Some parts are still available for these if you’re clever
Let us know what’s wrong with yours. We might be able to help steer you in the right direction and where you live.
John L
John L
Hey thanks, the compressor appears to be running but it seems the evap is not cooling. I need to get it pulled away from the wall so I can get
a better understanding of what is happening.
The refrigerator is located at our second home and I am just drained, I have my mother in hospice also having a new home being built near the
old one so every time I have a minute I work on the new house.
I do welcome everyone's help here and will respond as soon as I have a chance to get some gauges ( I assume there are ports) on the
compressor.
