My G7100SCi is "broken" I guess?
henene4
Feb 6, 2013
4,520
Heidenheim a.d. Brenz (Germany)
So, I recently switched jobs and moved. Had a moving company.
Don't have a kitchen right now. But set up my DW anyway and put my microwave on top to reduce the tipping hazard.
(Don't do that btw - it almost tipped over twice already. Only use free standing DW free standing - never use a built in DW without proper mounting.)
But - I encountered an issue on the last 3 cycles.
Thought it was just a coincidence once or twice, but now I think it did not take the transport well.
The detergent door does not open anymore.
The solenoid does activate (you can hear the click sound when you should and rinse aid is definitely still being dispensed).
But the door just stays closed. There is still spring tension on it. It just does not open that first bit so the spring can pull it fully open.
I'll have to do some investigation when this load is done.
But I don't think that I'll be abled to find out much.
I could with all likelihood fit the part myself.
But it's something like 150€. I could get a used one for 50€ somewhere I think?
But I paid only 550€ for the DW about 6 years ago (can't believe I have it for that long).
Right now I don't really want to spend money on a new one since I just had to pay the deposit for the new flat (which was a bunch here in the Munich area), I paid for the move out of pocket and I'll have to pay the monthly installments for the kitchen.
I can get along with it by just not using cycles with a pre-wash or waiting for the pre-wash to be finished.
But man - I don't think my moving company will cover that now and that would really suck if that I would really need to replace that part.
I'll keep you all posted!
So.
The component test does open the dispenser - but barely.
You know how the sound of the solenoid and the slide opening is basically simultaneous (tick-clonk) usually? Even with nothing in the compartment, there is like a half a second pause between the solenoid operating and the slide opening, as if it's sticking (click pause clonk).
These dispensers aren't designed to be 100% water tight (still don't know why, but most aren't today) and my guess is what ever makes it that bit sticky means that the powder detergent I am using is somewhat clumped up and keeping it from opening.
BUT
I checked the fault history and there was the dreaded F52 error.
I'll keep an eye on it for the next few weeks and check after every cycle if I get an F52 erorr again.
I am not entirely sure if I will bother with anything if the F52 becomes persistent.
A used dispenser and a used relay would be 90€ in total.
And fitting the relay is annoying.
But we'll see.
The machine has only 1426h on the clock.
Would be really disappointing if all that happens at once this quickly into the machines life...
The ebay article you linked is really interesting in a weird way.
The lid for the detergent compartment is missing, so you can see how it looks underneath.
That "ridge" like structure looks like a point for a spring to push against. Exactly the spring I think might be my culprit...
I will not have time to check today since I'll be ordering my new kitchen later today, but I have a plan.
I'm so glad to read this because literally last week I discovered that whenever my Bosch Serie 8 dishwasher is done with the prewash, the pod inside ends up in a semi melted sticky shape before dropping inside. I was even thinking of making a thread here.
After noticing this I wanted to check it and right after the prewash ended, I opened the door & the detergent dispenser, and there was water inside, with the colorful/gel part of the pod kinda melted.
I thought there was something wrong with the dispenser but didn't care much about it as it still drops in full shape when the main wash starts, but so glad to learn that it's normal lol.
I definitely would've wanted it to be fully water tight though of course, as these new Finish detergents apparently has "CycleSync" or something (which is probably just a marketing gimmick anyways).
Hope your Miele problem gets solved too!!
I think the general idea behind it not being fully water tight is something like pre-dissolving detergent or something - but most I know nowadays have some opening to let some water through.
Most pre-washes aren't that long either - I think my Miele with its 20min plus load sensing is at the upper end.
So I wouldn't worry to much about detergent wastage.
But yeah. I'm thinking about just checking if the F52 comes up again and if not to just sell it on.
With the new kitchen, I do have more height available under the counter and could fit a fully integrated model nicely.
Will be ordering the new front anyways as I was planning on replacing the Miele sometime in 2026 anyway - just not really right now.
Yep, the dispensers are designed to fill with water to pre-dissolve the detergent, as I found out many years ago when powder detergent was still the norm. I'd filled the dispenser with sun dishwasher powder, then decided there wasn't a big enough load to put it on that night, so chose to just run a cold rinse cycle with a drop of powder on the door and to do a full wash the next day. The detergent dissolved during the rinse and unknown to me crystallised and dried out enough to glue the flap solidly shut, so it didn't flip open during the wash the following night and everything needed rewashing, and as the detergent had by then been baked solid by the hot air drying cycle, I had to pour boiling water in through the slit at the top of the flap to dissolve some of the detergent to get the flap open.
I've blocked the inlet holes in my current one, because the seal around the flap leaks slightly during the pre-rinse losing nearly all the liquid component of the detergent pods.
Hi! I have a built-in dw I'm figuring out how to safely use against a wall that doesn't have cabinetry at all and was actually thinking a heavy microwave atop it would do the trick, too, till reading your warning. Did you resolve that problem? Thank you for any advice!
The thing is it's just not as solid as it should be.
I can pull out one rack decently loaded and it's solid.
But once you are in the heat of things shuffling stuff from one rack to another and pull out both the trouble starts. And unless you either have extremely fast reflexes or enough muscles, these things get dices quickly.
You can use it that way - the microwave does definitely offset most issues.
But the way the forces work on such a scenario, the typical concrete counterweights in the back bottom of a freestanding design are just better suited to the task. Not to mention the machine is significantly more noisy.
Thank you for the reply! My kitchen's so tiny with the fridge, range, and dishwasher all located on the one bare wall side (leaving just room enough for a roughly 15" wide rolling cart) that I was trying to avoid installing a cabinet for the dishwasher. But I don't have the reflexes nor musculature to right a tipping dishwasher :ROFLMAO:, and other than testing its cycles (I have the same soap-door-not-opening issue) I have yet to actually load it...thanks so much for your input. It helps me formulate a solution! Thanks!
