1963 Westinghouse Laundromat belt and bearings help please
fermdq
Member
Feb 16, 2017
8
Adelphi, MD
Can anyone help me find spare belt and bearings for my washer above? If not original I'll take compatible ones too. Please help!
Many thanks!
Thank you combo52. I'll PM you.
BTW, by the time I read your message, I did a bunch of research and found the belts & bearings dimensions and ordered them from suppliers of generic ones. The nice thing about this is that one can get any quality (e.g., kevlar belts, stainless steel bearings) or price you want.
FYI, here is the info for folks' reference.
BELTS:
Q12970
FHP V-BELT
Outside Circumference: 1193.8 mm / 47 in
Top Width: 12.7 mm / 0.5 in
Thick: 7.14 mm / 0.281 in
Q62144
FHP V-belt
Outside Circumference: 1358.9 mm / 53.5 in
Q62149
FHP V-Belt
Outside Circumference: 1054.1 mm / 41.5 in
Top Width: 9.53 mm / 0.375 in
Thick: 5.56 mm / 0.219 in
SEAL:
Q9303
Metric Seal
MOS-40-80-10R
BEARING:
Q500961
Type: 6205
Bore/Inside Diameter: 25mm
Outside Diameter: 52mm
Width: 15mm
Cheers,
F
CORRECTION
I was wrong with the seal dimensions above.
The correct seal dimensions are:
HT: 10 mm
OD: 52-53 mm
On the OD, the best seal probably depends on the state of your tub's bore. The best bet always is measuring the bore with a caliper once the old seal is removed. Also, if the bore is in bad shape, you could hack it by getting a repair sleeve #99205 for the bore and go for the 52mm seal.
FYI, generic seals are usually for oil/grease. I read a post here that the angles of the lips differ for water/steam/aqueous fluids and oil/grease seals, but I'm not sure how crucial this is for such a low-duty application like washers.
Modern Viton/FKM seals last way longer than the original rubber/neoprene/nitrile ones. Moreover, Viton type GF is specifically superior for water/steam/aqueous fluids so they should be a superior option, right?
Also, seals of other heights should work too if they don't stick out over the tub's bore edge. That said, does anyone have an opinion on using multiple seals (eg., two 5mm-thick ones instead of a single 10mm)? And how about using double-spring seals rather than single-spring? I ask b/c the contact surface on the shaft in my machine is 20mm wide and there is enough room to spare in the bore between the inner bearing and the seal.
Cheers,
Fernan
