ricky5050
Hi I've finally gotten around to trying to sort the problem with my washer. Thanks Mathew(Keymatic3203) as i contacted the link you gave and a branch nearby me supplied me with a belt that is a perfect replacement for only £8.00. I fitted it and tensioned it (which i thought it had been before but hadn't), (which is a bugger on this machine) as you have to remove a pulley to squeeze the belt in, then slacken a band type clamp (to allow the motor to rotate - and therefore causing the off centre main drive shaft move away from drum pulley - therefore tensioning the belt) and adjust a bolt to tighten up the tension. This all sounds easy but access is limited behind wires and pipes.(i could have taken off a side panel but that involves removing the top and front)
So it now has two perfectly tensioned belts with no shriek on start up , but i am sure the gearbox is not making noises it used to, you know how you learn all the noises your appliances make and anything a little different bugs you, well thats where im at at present.
The machine works fine but when spinning its a little noisier than it used to be, i know its the gearbox as the drum bearings are silent.The machine has been in use 9 years now so may be starting to wear a little.
The oil level is good but i still have auto box car fluid in as still not found anywhere to buy the modern equivalents (Thanks Electron 1100 for the info i still need to sort it ta!)
The does seem to be a stumble as it comes out of spin, the solenoid shifter works fine but it clonks as it goes back into normal drum speed .
So does anyone know if any replacement gearboxes are kicking about? haha i guess i could get it reconditioned if not too expensive.
I think i will investigate some new oil and try replacing it as it may have just becoming contaminated and new fresh oil make help.
Also i would like to thank Mathew again for a new Hoover TT pump as i now have that working fine so its always there to use occasionally
Here are some photos of the inside of the Bendix
Thanks
Richard
Thanks
Richard
