mattsdrag95
Hi Folks,
Have a beautiful condition 40" range that the right (large) side Bake and Broil elements stopped working on recently (smaller left side still functions perfectly, along with all cook tops). Model J486.
I replaced the right bake element and still nothing. I removed the back panels and found that while power is going to the main switch, that no power leaves the switch/dial when attempting to turn on bake/broil functions.
Upon looking at the wiring schematic I found the thermostat/relay (or responder as I have come to find called online) appears to show signs of damage (see photos below). Part # WB21x162. There are two other "responders" in this oven (one for the sensi-temp cooktop, and one for the smaller left oven).
I intend to do some further investigation to make sure the temp sensors are not causing a problem, but looking at the main responder it does appear to be damaged so I am suspect of it.
Does anyone know where I might be able to locate a replacement WB21x162 responder/temp switch?
Thank you in advance!
PS, please enjoy the attached photos of the range, as well as the near perfect original wiring schematic that I was fortunate to find inside the back panel!
-Matt
-Matt
