Kevin,
Thanks so much for your fast response. I did what you suggested and looked at the video on how to lift up the top of my washer and it was easy! I ran a partial cycle and looked down into the machine as it was running and found the leak coming thru the bottom of the tub. There is a flat metal platform which supports the outer round tub and the inner round tub in which your clothes sit in. The leak is coming from the bottom of the outer tub, filling the flat metal support platform and falling to the floor. I cannot see specifically if there are any holes because the round tubs are in place and I can only see the platform filling with water and going to the floor. Everything else is dry and machine cycles just perfectly. What next? Hope to hear from you and thanks so much.
Al Arnolfo
Al Arnolfo
