beekeyknee
I finished the 806 set the Drew gave me last spring. I finished the dryer early last summer and the washer last fall. Bear with me while I post. Thanks.
1: Bushing in spider that holds drum shaft. Wick removed for cleaning.
3: Wick removed, cleaned in kerosene and mashed between paper towels to dry.
4: Wick reinstalled.
5: New "O" rings installed in front of both bushings and area soaked with turbine oil.
6: Drum reinstalled in spider and fiber washers and snap rings reinstalled.
[this post was last edited: 1/24/2015-12:31]
www.automaticwasher.org
WAKE THE DEAD: TOL Maytag washer and dryer - $50 (Cedar Rapids)
Is anyone awake to see these - posted 2 days ago -better not think about it too long! No way can this be real : Ad says: " Older washer and electric dryer. Had hooked up in the basement as a back up set to the set in the laundry room but haven't used them in years. I washed and dried a load...
