1974 Kenmore “Green Beast” Rebuild
More progress
Since everyone has probably seen the underside of these machines a million times, I skipped the step-by-step on replacing the motor, transmission, and pump assemblies. Thankfully all of those went back in without any major issues.
The outer tub was next to be reinstalled. I sealed the outer tub center post gasket with rubber sealant just to be extra sure. The tub grommet and center post seal also got plenty of blue gasket maker added to just make sure we are water tight when the time comes.
The wash basket got a good scrubbing and is getting some POR-15 in those typical spots that’s tend to break down. This machine should be up and running very soon!
Finished product
Hands down this machine is a beast. Absolute struggle getting the spin tube in a sweet spot within the center post that would allow it to spin. I finally got it seated as best as possible. Spin is slow to start but once it grabs it’s good to go. The machine is rust proof and water tight. Definitely a great machine!
Congratulations Jon - you did an awesome job. Those look just as good on the outside as they do on the inside. Perseverance pays off. With that plastic tub and new center post they'll last another lifetime. Hats off to you!
