corvairstorm
Member
Hello again everyone!
So I decided to buy a older washer than my 1980s Maytag. I went with a Sears Lady Kenmore Washer. I believe it is a 1974.
I picked it up yesterday & got it home, hooked up & tested for leaks at the inlets, I didn't see any. So far so good. So I had clothes to wash & did a load. I noticed that it drips at the front right. I put paper towels down & continued. It spun without issues while still a slow drip at the front right. When it was draining, I noticed the piece it drains through seems to leak slightly around where it clips together. Gasket? After that I saw a hose looked to be rubbed into but not rubbed through.
So a few questions, I can't tell where it is leaking at the front right. It doesn't appear to be a hose although I'll attach a photo. Also the leak from the drain pump.... Looks like it will be difficult to replace that gasket. How hard is it to remove parts to get a better view of the leaks? The other thing is if it's all together I can do testing. Maybe I need to raise it up on stands & watch from underneath.
The picture looking down at two hoses is where the front right leak is but can't see where the drip comes from. Doesn't appear to be the hose but hard to tell. The other picture is of the drain pump where the water leaks past the gasket I believe.
Any advice or machine info would be appreciated!
Thanks
Kyle
Thanks
Kyle
