I recently bought a 1978 Maytag A806/DE808 pair in almond and have been in the process of refurbishing them with plenty of guidance from Ben (Swestoyz) and from past posts on this forum. I will share my story here soon, but for now I'll just say that the dryer is up and running and the washer is 95 percent there.
The problem I am still trying to resolve with the washer is that during the spin cycles, water will back up my bleach dispenser tube and overflow from the bleach dispenser funnel on the top. It comes up slowly during the beginning of the spin and then once the water has drained from the tub, it recedes from the funnel as well - but not before the funnel overflows. The overflow is enough that it is draining down the sides of the outer tub and down to the base.
I searched in this forum (and Ben also advised) that in most cases this is caused by the bleach deflector at the bottom of the tub pointing in the wrong direction. It should point counterclockwise so that it doesn't "scoop" the water during the spin cycle.
I removed my bleach hose and inserted a tie strap into the inlet of the bleach deflector (see pic) and I can only get the tie strap to go in a counterclockwise direction, which is correct.
I'm still using the original bleach dispenser hose (see pic) because it is still flexible and not hard like my drain hose was before I replaced it. I did shorten it about 3/4 of an inch at the tub end to get some fresh rubber under the clamp since the old rubber there was quite thin and hardened. The hose still retains the "crease" about 3 inches from the tub inlet which I'm not sure is there by design to impede backflow or just because it takes a sharp turn upwards at that point.
I did replace the water pump with one from Amazon that was described as "Fits OEM Standards! Guaranteed to Exceed OEM Requirements". Also replaced the belts and adjusted according to service manual specs. But I wonder if it just isn't draining fast enough during the spin?
I have tried loads on both Large and Extra Large fill settings and it backs up the bleach dispenser for both. I don't remember it backing up at all when I ran my initial test for leaks with just a small load of water without clothes.
Any ideas would be appreciated!
Thanks - Jeff
Thanks - Jeff
