Hello,
Hopefully you all remember us with the GMC motorhome and the late 70s whirlpool portable washer dryer set. I'm at the point of doing the wiring the dryer and apparently generators can only produce 220 or 110 power, I was hoping we could run both machines in the coach at the same time off the generator. The generator were told works for the coach is an Onan 7hgjae. My question is, isn't 220 just two 110 legs and therefore can we not make a switch that will allow the dryer to run on 110 or 220 by powering or not powering one leg of the 220 plug and just leaving the RV generator in 110 mode? We will just be mindful of not running anything else in the coach when the dryer is in 220 mode. Thoughts? If this is possible is one leg of the 220 motor and one heating element then another leg just the second element? Any idea which leg is which?
Thank you in advance, looking forward to posting pics. We will be using the RV to promote a new website (a different kind of social media that resolves conflict and helps people get along) so people will be coming on board the coach to check things out and I'd love to be able to show the machines working on generator power (110 mode heating in the dryer when anything other than just the dryer is on). Plus we will likely find ourselves at university campus' and not plugged in.
