1E error samsung wf600 front load
dadastar
Mar 11, 2023
sweden
Hi, I was hoping someone could help me, because this error comes and go.
sometimes when I power on the machine, 1E comes right away.
and other times I choose program, hit start and 5sec it comes.
I have clean everything, all pipes, even change pressure level sensor.
I have read that the error indicate problems with water source, but water pressure is high, today I just wash 4 times no problems at all. But later at the day, error comes again, but so later again I could wash, how come?
Is it taking in any water? The 1E error means it is not detecting any water coming in.
Most common reasons for "no water fill" error are:
1. inlet valve failed
2. strainer blocked in water inlet hose - at tap end, or in valve where water hose connects.
Should be easy and low cost to fix.
but how it can detect no water? before I even hit start on the washing machine??
yes sometimes it do wash a whole program without problems, but error comes again.
inlet and filter is cleaned and a lot of water comes out.
I was thinking there is something wrong with the main board.
I missed where you said it does the error as soon as you power on - before starting a cycle.
I would guess a main board fault then? Or maybe a faulty inlet valve?
Many late model machines do a quick "self test" when powered on - check valves, pump, motor, heater before even starting a cycle. It might be detecting an open circuit inlet valve??? If you have a spare inlet valve, that would be quick and easy to check, otherwise main board would be next thing on my list.
