andrewinorlando
- Joined
- Oct 18, 2004
- Messages
- 1,392
After 2 weeks with the LG 9810 dishwasher, even as skeptical as I was, I have to admit that it's a pretty spectacular machine.
The cycle times have proven to be very manageable. The Normal cycle has never run more than 1:45, and that was just once for truly filthy load, including dry time, but seems to average about 1:20 most of the time. Coincidentally, the my KitchenAid Superba Selectra took about 86 minutes to run it's normal cycle, which is about 6 minutes longer than the LG's average. Big difference between the two though, is you can get about twice as much in the LG as you can the KA. The LG's upper utensil rack is very handy for silverware and wooden spoons, ladels, etc. It also does a very good job, and is very convenient.
I find the Quick cycle does a pretty decent job on average, everyday loads. It runs for about 45 minutes (without dry) and 1:15 with the drying portion. It won't clean stuck on/baked on soils - it just doesn't get hot enough. But for mixed loads like coffee cups, the coffee pot, the dog's dishes, it does a pretty good job.
The biggest boon is the fact that the machine operates in complete silence. There is just no sound at all. You have to touch the machine to feel it running, and even that is a very faint vibration.
Both the Power Scrub and the Soak cycles do a wonderful job with the Steam option. If you face heavily soiled items towards the steam nozzles, as I did with a broiler pan, and a frying pan, it does an awesome job cleaning even burned on soils. Any remaining residue just wipes away with a damp cloth after the cycle.
One thing that is a must for this machine is JetDri. It just doesn't seem to dry well at all without it, except on the Power Scrub or Soak cycles, which heat up to around 160 degrees anyway. In contrast, the GE Tall Tub had no problem drying anything at all without JetDri, but the LG just doesn't stack up in that department. Biggest pain in the ass though, is you can't leave the door open to flash dry the dishes overnight because the interior lights stay on when the door is open. Not a big deal, just different.
All in all, I'm extremely pleased with it, especially it's enormous capacity and ability to hold large items. Even serving platters fit on the top rack with the upper utensil rack removed and the rack in it's lowest position.
Since this is the same machine that Eugene had posted photos of, I haven't included any here. I tried to photograph the control panel, but because it is all backlit, it is almost impossible to get a good shot of it.
All in all, worth every penny, and it's built pretty well.
