2018 DOE Regs Front load washers/ Speed Queen Front Loaders
dylanmitchell
Jan 7, 2018
124
Southern California
Did SQ make any major changes to 2018 vs 2017 and prior FL washers? Know TL had additional restrictions for 2018 but believe FL stuck to the 2015 standards? And are any changes coming up?
I want to add a SQ FL to my laundry room someday and want to stay ahead of changes that might affect performance. I have a TL SQ and SQ dryer but want to add an FL to the mix.
Thanks!
The stack
is still in production, so just get one of those. Still available with gas or electric dryer. The FL washer in the stack is identical to the single unit washer.
If you should happen to only have space for 2 units, then buy the stack and remove your current dryer.
Problem solved!
