50's Frigidaire Imperial Filtrator
Looks nice & clean.  A terrific looking 1955 model.  Congratulations.  Now you'll have fluffy, soft towels next winter with a nice fragrance in your basement when you dry them.
The Idler pulley switch turns off the motor if a belt breaks, and the motors centrifugal Sw turns off the dryers heating elements, because of the exposed intense radiant heat from the elements on these dryers it could be a fire hazard if the elements were on without the drum turning.
Condenser dryers can produce softer clothing because of the damp steamy drying conditions in the dryer.
John, thank you for putting in to words what I knew but couldn't verbalize appropriately the aspects of condenser dryers.  Frigidaire Filtrators are the only condenser dryers I've ever used.
Filtrator experts!!
As you can see, I have a ways to go with testing the heaters and motors, etc, but a few things already worry me:
Thermostats and safety limits: I see one eprating/running thermo, it's a capillary tube that is part of the temp switch, similar to stoves. Then there's the high-limit rusted out thermo on the back of the interior, a few inches below the heater box.
Picture above with rust-through, reply #14. The 1952 manuals list it as 239F, and I'll replace it as I start ordering/finding/cleaning/painting.
Is that all? Shouldn't I likely wire in another one somewhere? IT just doesn't seem like enough. Maybe a somewhat lower temp one located in a new hole I'll drill through one of the 2 huge baffles that sit immediately below the drum?
But I have a ways to go before I get there--True.
