50's GE 40" Pink Range-Need Model Number
spin2start
Oct 29, 2015
2
Hi, I've just found this wonderful vintage GE 40 inch, double oven range. It's a lovely pale pink. It also has the Sensi-temp feature, along with the rotisserie, and 2 electric outlets, one with a timer.
My problem....the model number has been scrubbed and I can't read it....anyone have an idea as to what model range I have?
Beautiful Range
Your range is a 1959 model.  I do not have the 1959 literature, but earlier years and later years both identify this model (40", dual ovens, TOL) as a J408, so it's very likely that this is your model number as well.
lawrence
Finding Model Number
Hi, thanks for all the info you've shared about my stove!
I did find (what I think is) the model tag. There is a metal tag riveted in the space between the 2 bottom drawers. Problem is someone has scrubbed it to the point that I just can't read the numbers! I swear, if it were a gun I'd think they were trying to rub off the serial number!....lol...
Anyone know where I could find a manual for it?
Thanks,
Lori
Theres a downloadable 1957 manual available here for $3.99 in the "Manuals & Literature" section. If you specifically want a 1959 manual try ebay.
Wow, that must have been some scrubbing! I wonder if the model number would be readable under UV light?
On my 1966 and 1969 GE ranges, there was a schematic diagram -- with model number -- tucked into an envelope glued to the inside of the upper back panel. Can you remove the upper back panel -- please unplug the range first! -- and see if there's a schematic in there? Good luck.
Dean
P.S. -- That is an absolutely gorgeous range!
1959 might be old enough that the schematic was still glued to the back of the range.
Pink stove
love coming at you from over here. Can we see the rest of the kitchen this beautiful old gal will live in?
