50's...Not~!......That 70's Show
I doubt 50's
Gary, I sort of doubt 1950's, too. Late 60's to late 70's seems more likely to me.
I remember seeing one in action once. It actually worked...was a water hog, tho'.
If the price doesn't matter, sure - why not?
I'd like to see a shot of it running, if you do get it.
Keven
give the Carocelle a spin
The Carocelle dishwasher debuted in 1969,and actually works quite well on all but super dried on foods.By using liquid enzyme laundry detergents instead of liquid hand dish detergent,which is what it uses,the results will jump even higher.Since it takes a few minutes anyway to fill up your sinks with water,and since you don't do that with this machine,but that water which woulda filled up the sinks is spraying the dishes,the water use is not much higher.If the dishes are really crusty,here's a suggestion.Once the soapy water starts spraying ,turn off the hot water and let the dishes sit there wet for a while,sorta like KA's so-called soak cycle.Start the spray again,let it finish,and Voila!now even the scankiest dishes will gleam.
I remember them well. Everytime Dayton's had a sale, it was in the catalog. $39.95 I believe was the price. Never did see one running though, and didn't know they came in decorator colors!
So what made it work anyway? The water sprays the dishes and then it drains out of the bottom? I only see one hose going into the base so is that the fill/drain hose?
hydrodynamically speaking
It takes hot tap water thru the hose,forces it outta 23 jets that whirl like a revolving lawn sprinkler,while constantly draining.Meanwhile,you squirt some regular hand dish soap,such as Dawn,but liquid laundry soaps are better, in the reservoir,which siphons the soap into the flow.When the water runs clear,the dishes are rinsing.After 5 min.,turn tap off,lift off lid,the dishes will air dry.
