captainmoody
- Joined
- May 22, 2006
- Messages
- 348
I decided to get busy on the Norge yesterday, and get it going. When tested, all the motor would do was hum when the timer was in agitate or spin mode. To repair this, I had to disassemble the motor and repair the centrifugal switch assembly inside. (Lucky for me, the windings weren't toast!)
Once that was done, and all the paint spots, grime, and yecch was cleaned off the cabinet and tub, it actually worked!
All I could do was a quick test, as the drain hose I used was too big for the pump, and the rig with electrical tape to make up the difference was leaking!
There is some (but not a lot) of old tranny oil residue on the pulley and the sides of the machine indicating it does leak, but none dripped out when using it for now.
It is a nice running machine, and I especially like the solenoid "clunk" at the spin cycle!
