"I'd also challenge the blanket assumption that front loads always clean better when it comes to soiled diapers, shop rags and exceptionally muddy/greasy work clothes."
Challenge all you like, but it's a proven fact that h-axis washing machines will get all sorts of soiled laundry cleaner using less water per pound, and with causing less stress/damage than top loaders with central beaters.
Industrial/commercial laundries long have used h-axis washers to process everything from hospital linen to diaper services, and results are spot on.
Now what is achievable with a truly industrial washer that has far more changes of water than most domestic front loaders, is built to withstand use of stronger chemicals, has access to or can produce hot water at temps 140F to 180F, and is allowed to used enough water per pound to get job done, well that is another matter.
Average domestic front loader is being nobbled by same laws/rules on energy conservation applied to top loaders, which is silly. H-axis washers already use less water per pound than top loaders so across board standards are stupid.
Here is standard diaper service wash formula from 1950's
(1) Five-minute cold rinse;
(2) 10-minute soak in hot suds;
(3) 10-minute soak in hot suds;
(4) 10-minute soak in hot suds, with bleach;
(5) five hot rinses with live steam;
(6) six cold rinses, and a germicide solution is used in the third cold rinse;
(7) water is extracted;
(8) dried in tumblers under 125 pounds of live steam;
(9) ready for folding and packing.
Here are some standard modern wash formulas:
http://www.uschemical.com/wp-content/uploads/2016/04/L000241_Laundry_Formulas.pdf
What industrial laundries have over domestic washers is ability to do far more changes of water (especially flush, wash and bleach cycles), which is what carries away muck.
Back in day as part of "Normal" cycles front loaders always did a pre-wash. That's gone by wayside in most part though some machines have "Heavy soil" programs which incorporate a pre-wash. But in industrial setting even that pre-wash (or first wash cycle) would be proceeded by a "flush" cycle regardless.
"We Don't Wash In Dirty Water" is the maxim for laundresses, laundries and and anyone else doing the job going back ages. No laundry will ever be cleaner than the water it has come out of, so if you don't flush or otherwise remove gross muck (via many changes of water for example), you're not going to get good results.
Modern commercial laundries (including those that process diapers) deal with heavily soiled loads all the time. When it comes to diapers everything goes into machines as it comes out of bags, including solid waste.
post was last edited: 7/17/2022-17:43]
