philr
Joe,
I never had to replace one of the tabs on the lock ring, I was careful not to break tabs on mine and reused it without problems but I don't think I could have done it many times!
Pat,
There's something that makes noise, I can see that the agitate roller isn't moving smoothly, it's hard to tell if it's what makes that noise or not. Look at the roller for a flat spot...
You can try to move parts manually while the washer is disconnected. If the ball joint, the acorn-shaped coupling above it, the agitate shaft bushing or the agitate arm bearing...
Pat,
