90’s whirlpool washer
tomdawg
Aug 3, 2015
169
Des moines
I picked up this old whirlpool washer. A Friend of my dad gave them to me.
I tested it out and noticed right away the “Dog ears” were shot. Motor coupling sounds like they are about to go out. The washer kinda had a vibration when washing.
Washer leans to the right when washing.
To my surprise, neutral drain worked!
The first time I ran it, the rinse cycle wash didn’t work. It advanced through the cycle, but it didn’t agitate at all. I opened the console and blew into the timer and some dust came out. Did two more loads and it worked just fine. Not sure why it did that.
I got a few things to do, to get this old lady working like new again!
Couple questions.
1. What would cause a tub to lean? Bad springs? It was fairly level. Maybe leaned back a little but majority of the Bubble was in the middle.
2. The tub is throwing me off, I thought whirlpool didn’t make the “swirl” holes until the next generation. I thought it was much like the maytags where they had lots of holes in the tub. If so, I wonder if they had a new tub installed.
90s direct drive problems
The wash tub can lean for a number of reason. Sometimes the whole frame is bent a little bit from the machine being dropped. Sometimes you can add a spring. If it really bothers you to pull it over a little bit. It’s usually not the three centering springs.
It could’ve had the tub swapped although I tend to think it’s original if you bought a replacement tub they always substitute a white one, so that would not have been a new replacement tub but someone could’ve taken it out of another Machine.
