!957 Maytag Washer??
Changing The Tub Light Bulb
You take the front panel off then unscrew the top of the washer [ two 3/8"] bolts toward the front and then raise the washers top.
The light bulb may be stuck in the socket from corrosion, you may want to use a little penetrating oil on the base and it may break the glass so be careful.
