ryner1988
I've done a lot of thinking over the past couple days about my washer situation (see my last thread for reference) and have also spoken to a few people. Without going into too much personal detail, we will be getting quite a bit of extra money over Christmas, so with that, coupled with my newly acquired Lowes gift card, I'm in the best position I could ever be to finally buy myself a front loading washer. So, I believe it's time. I've heard the arguments both for and against them for years, and I've always wanted to try one but never have had the funds. Well, now I do, and I think I'm going to pull the trigger.
I've done some research and I'm not sure the Whirlpool/Maytag machines will fit in my 40" deep laundry closet, but I believe machines by LG and Samsung will, as long as I stay within the 4.5 cu. ft. models.
Here are the machines I'm considering:
LG 4.5 cu. ft. washer in white, model WM3400CW
https://www.lowes.com/pd/LG-4-5-cu-...2544016?idProductFound=false&idExtracted=true
LG 4.5 cu. ft. washer in white, model WM4000HWA
https://www.lowes.com/pd/LG-High-Ef...3203118?idProductFound=false&idExtracted=true
Samsung 4.5 cu. ft. washer in white, model WF45T6000AW
https://www.lowes.com/pd/Samsung-Hi...2890950?idProductFound=false&idExtracted=true
Samsung 4.5 cu. ft. washer in white, model WF45B6300AW
https://www.lowes.com/pd/Samsung-4-...3150247?idProductFound=false&idExtracted=true
With that out of the way, here are my list of questions for all you front-loader heads out there. Please excuse my ignorance as I've been a top loader user literally all my life.
1. LG's machines measure just over 30" deep, and Samsung's come in at just over 31" deep. Will these fit in my laundry closet with approx. 40" depth?
2. Are the editions of Turbowash and Superspeed on the LG and Samsung machines, respectively, worth the price jump? The budget machines in both brands seem to have everything I need, although many people complain about long cycle times with those entry level models. Also, the Turbowash/Superspeed models come with other add-ons that I don't care about at all, like WiFi. But, if there really is an argument for the editions of the recirculation in order to cut cycle time, I'm certainly willing to take it into consideration.
3. Is Samsung really, truly, honestly that much worse than LG? I've heard this over and over, but there's a glaring, obvious, compelling reason for me in particular to choose a Samsung over the LG. Both have touch controls, but Samsung has made them accessible out of the box. There are dots underneath key cycle buttons, as well as variable tones for choosing temperature, spin speed, etc. To my knowledge, LG does not have this. There are no raised dots on the control panel, and it's just the same beep no matter what button is pressed. No matter how poor Samsung's reliability allegedly is, this is a big plus in their collumn, and I simply can't ignore it. However, I'm sure that an LG's controls could be made usable for me with modifications. I could put my own bump dots on the control panel to find key buttons like temp and soil level. Here's my question though. Do LG's FL's default to a default state every time they are powered on? What I mean by that is, does it always return to, say, the normal cycle every time? If so, I could easily learn to count how many clicks of the dial it would take to get to the cycle I want, provided this acts the same way every time the dial is used. I could also learn how many times, for instance, to press the temp button to get to hot if a cycle always starts at warm, or how many times to press the rinse button if a cycle always starts witha default number of rinses. So, is me learning those work-arounds worth it for the LG's alleged better reliability, or should I get a Samsung with accessibility pretty much built in so that I could use it straight out of the box?
4. I understand that front loadres require a bit more maintenance than top loaders, i.e., leaving the door slightly ajar between uses, wiping out the gasket, etc. The problem with leaving the door open is that the laundry closet is in the hallway, and Stacye has to get through there in her wheelchair to access the bedroom and back door. As I don't do laundry every day, would it be okay to leave the washer door open for a day or so so it can dry out, and then close it for the rest of the week or until the machine is used again? I can't see how this would hurt anything or cause the machine to get gross, but more experienced folks can chime in.
I think that's everything. LOL! I would really appreciate some thoughtful answers to my questions, as this is a big investment for me. It's also possible I may just wimp out, have my basic TL repaired, and stay in my comfy bubble. We'll see. But I really think I'm going to jump it. I'd just like to go into it armed with some good information.
So, front loader peeps, feel free to chime in below with any advice you have.
Hope everyone is having a good weekend!
Ryne
Ryne
