A Miele MONDIA 1300???
bajaespuma
Mar 16, 2006
6,258
Connecticut
I've been prowling for a Miele for some time now. I had my sights set on a W1918 because I wanted
<ol>
<li> a boil wash machine</li>
<li>a machine that ran on 220V (so I don't have to wait 4 hours for the water to heat up)</li>
<li>a machine with a 1600 rpm spin.</li>
</ol>
Missed a couple for various reasons then I came across this one that I bought today from a really nice woman in Westerly RI who had it listed for 100 dollars. Not only had I not heard of this model before, but, as you can see from the pictures, it's a German machine actually from Germany for Germans. It looks like the Deustch version of the W1918, but you Miele experts will fill me in.
One of the things that's great about this hobby, is that I go to parts of my little world that I wouldn't necessarily get to see and sometimes meet some great people. Westerly RI is well-known around here as a beautiful shore spot on the Atlantic and it sure is. Even better, the couple I'm buying this from are interesting people. I told Sarah that she should ask more for the machine but she is one of those people who said, "hey, if I can get a hundred dollars for it and have somebody come and take it away, I'm happy". Her husband is German and they are about to move back to Goettingen(sp?) for a new job. Apparently they calculated that it would cost them much more to transport the washer with the rest of their furniture in a container than it would to just buy a new Miele when they get there. Makes sense, but they are taking the new Miele dryer that was in the laundry room with the MONDIA. I knew that the machine ran on 220 but I was worried about the 50 cycles issue. We called Martin at work and he told me that the machine runs on either 50 or 60(is that Miele planning or is that just they way it works with cycles?). I told her that even though I was getting this cool machine I was sorry they were leaving because, for various reasons that I discovered by talking to her and being in her house for 1/2 an hour,  we would have become fast friends.
Anyway, for a mere 100 dollars plus some time and work to bring the thing home, I have a new toy to play with and possibly use as a daily driver. The drum is tiny so I may just keep the 1-18 hooked up for the odd quick big load.
She gave me the instruction booklet; I'm going to have to learn German to use this thing properly.
nice find...
Control panel does look very similar to the 1918 but there are differences. Not sure if parts are interchangeable, but we have a 1918 and matching vented dryer that we are wanting to get rid of.
The washer has had a few new parts over the years (control board, power supply, brushes, boot) but finally gave up the ghost when the spider failed. Replaced it with a lightly used 1986 set that was in a vacation home on the Cape.
If you want the 1918 and the dryer (it works fine), you are welcome to them. I am in Danbury so pickup should be easy.
Let me know if you are interested.
Alan
Congratulations on your Miele. Your Miele is not so much similar to the 1918, more to the 1903. The 1918 is deeper because it is based on Miele's commercial line. Yours has a higher spinspeed and some more options than the 1903 though. I see it has the "Einweichen" function, which is a soak option. It means that this is one of the last models with the vertical push buttons. Later models had the horizontal buttons like the 1986 has.
The capacity of this machine is 5kg, or 13lbs, so indeed somewhat less than the 1-18. But you'll be amazed how much a compact frontloader can hold.
If the German language is a problem, we can help you out.
Actually the 1903 and the 1918 are the same size
At least the cabinet is.... According to the manuals available on the Miele USA web site they both are 33x23x24 and weigh 220 lbs.
Louis, are you thinking of the 1926? THAT machine is deeper (as is the 1986 which followed it, much to my chagrin!) and has a larger capacity (6 vs 5 Kilo). I also recall someone on the forum saying the 1926 and the earlier "Little Giants" were very similar.
"machine runs on either 50 or 60"
For years we have been told and often repeated here in the group this isn't true; that is the difference in cycles (running on 60hz as opposed to 50hz) would affect performance of Miele appliances sold for the European market. Obviously now that thought will have to be changed.
no worries Louis
Often times I think that I am right about something only to be proven wrong. I can blame age but not Nutirsweet. But it could possibly be the champagne. :-)
