tbolt - Yes, this machine has an off-balance buzzer. Most of the better Kenmores do, but in 1980 you had to have the third or fourth 70 series (out of four) or better to get one.
Greg - Yes, the detergent dispenser IS cool, however yesterday I wound up cursing a storm at it. I used the machine in the morning to wash the towels that I dirtied during the testing and install of the '82 60. That went fine, but somehow the detergent solenoid got wet (I did let the 82 drain into this machine with its test water), and since it had more of that detergent residue that was everywhere else in the machine, it stayed wet and gooey. Every time I would plug the machine in, immediately the garage GFI would blow. Without a working test meter, I wound up eliminating one thing after another trying to determine what would cause this. Couldn't believe that the solenoid in this machine is hot all the time. I knew the timer and cycle modifier switch would be, but the detergent solenoid? WOW Without the solenoid in line, the timer is dead in the first 6 minutes of wash in Normal, all of Delicate, and the first 4 minutes of Perm. Press. The function of the Pre-Soak and Pre-Wash was unaffected since the dispenser is not used in those cycles.
I'm going to have to get the solenoid out of the machine, clean it completely, and cross my fingers that it isn't shorted out. I worked on that problem for at least four hours!! Talk about frustrating each time I'd plug the machine in and hear the instant 'pop' of the GFI. Glad to know it works though, lol. By the time I disconnected the solenoid, I was getting pretty punchy.
Another note to self - get new batteries for the test meter!
Gordon
