A 'tag in my garage
That is the same Maytag my mother used for 21 years. The belt broke, shortly after my father had a stroke, so she let the Maytag man take it and leave a new one in it's place.
water level
Glen
Any leak in the hose will cause the hose not to activate the pressure switch.
3 guess says the hose either dry rotted and split or a the machine has had a guest.
If it's filling too high, there's probably an air leak in the tubing going to the pressure switch. Best bet is to replace it. And yes, it takes quite a bit of pressure to trip the pressure switch!
Someone could have also tweaked with the set screw which would cause the same thing...but that doesn't seem logical.
Glenn,
Was Don at your housewarming? I think I remember him joking "How many women does it take to fix the coffeemaker?" when the catering lady forgot to put the lid on and water spilled everywhere! LOL
Yup, the pressure hose was cracked and broke completely when I pulled it off. Perhaps all the hoses should be replaced.
Interesting, a replacement outer cabinet apparently is still available. Ran across it on Sears Parts for $211. Any opinions on whether that expense is justified? Would be nice to get replacements for the nasty console and corroded trim, but some of those pieces are NLA.
Parts Needed
I've found another problem. Low speed motor won't start directly. It'll run on low if I get it going on high speed then switch to low quickly without the motor shutting off. I assume the cause is a bad motor switch .... ? Or the motor itself?
So thus far I need --
For sure, water level pressure hose and apparently a motor start switch.
Probably, tranny & pump belt.
To be safe, hose from water valve to fill injector (has a crack starting), fill injector nozzle & tube, hose from injector to tub cover, and hose from tub to pump.
RepairClinic .. here I come!
Glenn, refrain form getting a new tranny as long as possible. The replacement will be the orbital tranny, which has the faster, shorter stroke, rather than the helical drive tranny that's in this machine.
