A Tale of Two Corning Electromatic Skillets
rp2813
Jun 16, 2006
18,014
Sannazay
A while back I found a Corning Electromatic Skillet and subsequently found a Cookmates casserole to fit it.
Within a few months I found another skillet that was priced right so I picked it up as a spare or potential gift, and have since found a couple more vintage Corning A-10-B casseroles.
Today when I was rearranging things I discovered that none of my A-10-B casseroles or the Cookmates would fit on one of the skillets.  They were all slightly too big at 9.75 x 9.75 inches square.  They all fit perfectly on the other skillet.
Both skillets appear identical -- until you flip them over.  The one nothing fits on is a model P-12-ES.  The one that they fit is a model P-12-ES N.
So now I'm wondering what size/model Corningware Casserole is designed for the P-12-ES.  The later (?) A-10-B types that measure 9.5 x 9.5 are too small and can slide off.  Did the P-12-ES have a specific casserole paired with it that measures 9 5/8 x 9 5/8 or something?
Ralph:
I don't have an answer for you, but I will be very interested to see if one turns up. There are tons of little mysteries with Corning Ware, stuff that no one has figured out a reason for. Just when you think you know it all, you get faced with something that shouldn't be, but is.
Hopefully this is something that has an answer.
Corning changed the shape of the Electromatic skillet pans when the P series pans changed to the more straight-side profile and wider handle ears of the A series. The older P series skillets had a higher domed Pyrex cover than the A series. I think you will find that the brackets on one base extend slightly further over the platform; that is the one for the older P series skillet. The base for the newer skillet with the slightly shorter brackets was only made for a short time before Corning changed to the newer style heater base with the flat heating area bordered on the right by the 2 inch wide semi woodgrain surfaced area with the metalic knob for the temperature settings. It was sort of a portable counter that cooks. Unfortunately, that one had nothing to keep the pans on the cooking surface from spinning and sliding around. I sold all three versions and had to deal with ordering replacement pans for both platforms with handles and brackets.
. . . something that has an answer
It apparently is.
Thanks Tom.  I knew the brackets were the only difference between the bases, but didn't know why. Going forward, I'll know to pass up any A series dishes and keep an eye out for the P series, and/or watch for another P-12-ES N base.  I've seen various kinds of Pyrex lids -- the lower profile type with small knob, the higher profile with larger knob, and higher profile with small knob.  Are these generally interchangeable between older P series and later A series dishes?
I have a couple of the newer style heating bases with woodgrain side panel as well.  I've never used any of my Corning heating or skillet bases to cook on.  I bought them to use primarily as warmers.  It's cheaper and easier to cook on my gas stove.
