I am new to vintage washing machines, but I am experienced with mechanical items and electrical equipment. I recently bought a nice condition A606 washer that 'works'. The machine will cycle manually and operate on all functions if you turn the dial manually. Very clean, runs nice and smooth.
I took the back control panel cover off and I could see that the timer motor was NOT turning. I was able to track one down no problem, swapped it in and it still would not cycle through the functions as I thought it would. I took the timer mechanism apart and I found one burnt contact.
I took 400 grit sand paper and cleaned all the contacts, cleaned up the interior of the mechanism and reassembled. The one burnt contact, I sanded as clean as much as I could, there is still plenty of material on the contact. I ran a continuity test on all the contacts, so far so good.
I installed the timer back into the machine, same problem. No cycling through the functions. I cannot see the round end of the shaft turn at all (has a nickel sized back). I know there is an adjustment that can be made to get the gear to be turned via a pawl and gear. Not sure how to adjust so I just put it back to the same spot the screw was from the factory.
What am I missing? Can't find one on eBay either...... 2-4476 is the number
