Thank you very much for the compliments guys.
With any luck I'll still be worthy of them when this project is finished. Now since it was suggested that I might trim the rivets that are too long and still make them work(at least I think that's what was being suggested) I thought I'd make this quick drawing so I could explain whats going on with these semi tubular rivets.
The little image on the left simply shows a cross section of one of them. The hole in the end that's labeled "D" will be the exact same depth on all 1/8" diameter semi tubular rivets. Only the overall rivet length will vary depending on the application.
The image on the right shows a properly sized rivet that's been correctly installed in an imaginary Bakelite timer body, and the tubular end of the rivet has curled around and come in contact with the tab labeled "B."
If the rivet is too short for the hole it's being installed in, surface "A" of the rivet set will come in contact with tab "B" before the end of the rivet has been properly rolled over. At that point nothing more can be accomplished by further squeezing. You'll just be squeezing the Bakelite.
If on the other hand the rivet is too long, the tubular end will continue to roll over until the point labeled "C" on the rivet set bottoms out in the hole. At this point if one continues to squeeze, the solid brass portion of the rivet will begin to compress and as it does it will swell exerting outward pressure on the sides of the hole it's installed in until the Bakelite brakes apart. This would be a very bad thing, and it explains why a rivet that's too long for a particular hole can't simply be trimmed down.
I hope this clears things up.
[this post was last edited: 10/26/2013-18:15]
