abcomatic
I used my 1954 ABC wringer today and a problem arouse. When I plugged it in the motor ran but when I put the machine in gear, it wouldn't go until I worked on the agitator for a bit trying to make it go. It finally did but there was smoke coming out from under the skirt for awhile until the agitator started to move and things went well. I was just finishing wringing out some clothes, backed the wringer in the opposite direction to correct a sock from being caught. The wringer wouldn't respond nor would the agitator. The transmission seems to be ok, no loud, strange sounds that shouldn't be there.
Any ideas that you can think of that could be causing the problem would be appreciated. Thanks, Gary
