About as BOL as it gets.
cam2s
Apr 9, 2012
315
Nebraska
This came accross on my local craigslist and I thought I'd share here. I know some people enjoy BOL machines and these certainly fit the bill. The washer doesn't even have selectable water temps in the timer, it's a warm wash cold rinse. The agitator is a lovely shade of grey too.
oh my gosh!!!
how much more "basic" can you get than this set of washer & dryer!!??!!?? i don't think it gets any "plainer" than these here!!!
i would have never guessed a washer or dryer would be as basic as these!!!
LOL....
thanks for sharing this post. i really got a kick out of see these pictures.
:o)
True BOL machines. I'm actually surprised the dryer has an automatic cycle on it as opposed to just a timed cycle.
Even though the washer has only one temp setting programmed into it (warm wash, cold rinse) you can alter your wash temp to what you want by adjusting the water supply faucets. It just depends on what you want to do to achieve the temps you want. Where there's a will there's a way by all means.
Yes, I would have thought a clockwork timer would be the simplest and cheapest form of dryer control.
Dryer
I have that dryer. It's got very accurate controls, you just set it at that star and hit the button. No buzzer or anything, but it works well. And will probably run forever.
The washer-----I wouldn't want it, true, but as a college kid it would have been an improvement over carrying laundry baskets to the bus to the laundromat. I would have loved it. It would be easy to turn off the cold water at the start to get a hot wash, then just turn the valve back on once it fills, you'll get your cold rinse.
I bet Sears priced them right in the day.
Capacity
These would be the same capacity as a coin-op machine, right? So why the issues with doing full loads?
Also, that indicator in the timer dial at the 11 o'clock position, is that the last increment of agitation before draining wash water or the dry agitate setting?
Malcolm
BOL Sears Washer and Dryer
These were made as an advertising enticement to get people into the Sears appliance department in their stores. The interesting thing is they only cost a few bucks less to make that the pair that was priced for hundreds more that Sears wanted you to buy.
That said I would have NO PROBLEM using these as my only washer and dryer for the next 20 years, I can certainly think of much worse machines to have. Back in the mid 80s when we got a lot of the basic 24" single dial DD washers on product exchanges I would always bring them into my home shop and do all my laundry in them with no problem at all.
The dryer has auto-dry because auto-dry is required on all dryers to save energy and also to help protect against over drying to reduce fire risk.
