easy
I'm hoping someone here has had a similar problem and can suggest a solution.
This dishwasher has been in use for 9 years after being in storage for a couple of years. The control panel has a cluster of touchpads where you select cycle and options. The control panel has an outer layer of plastic/vinyl that is bubbling up and coming off in 2 or 3 places. The printing under the plastic covering is in excellent condition.
I don't want to peel all the plastic off as I'm afraid that the printing will come off fairly quickly without protection. The control panel is NLA and have been unable to locate a donor machine.
Has anyone had a similar experience? Is there some kind of liquid plastic that I could paint on that would dry to the right flexibility and function like the original? Is there some kind of peel and stick clear vinyl that might perform well?
I would greatly appreciate any suggestions as I like this machine and would like to keep it going as long as possible.
David
David
