Friends,
I need some help and advice on my Kitchen Aid KDS-57A portable dishwasher. I purchased this a number of years ago and never ran it until this past weekend.
Before running for the first time, I put a couple gallons of hot water inside and closed the door and let it sit for 2+ hours. There were no leaks. After I hit the "Cancel/Drain" button and the machine emptied completely of water and shut off.
I put in some dishes and detergent and tried it on a full cycle. The pre-wash cycle went fine. When it moved to the wash cycle, the first few minutes everything was fine and then water started leaking out of the bottom of the door. I shut the water off from the sink and hit the "Cancel/Drain" button and it cycled through and emptied out completely. I tried it two other times with the same result.
What is happening? Is there a seal I need to replace? Something else? If any of you know a fix to this I'd really appreciate it. The machine is in beautiful condition and I'd really like to use it.
Thanks so much!
Thanks so much!
