Greetings to everyone from a very locked-down Italy for a very long-time. I have an AEG Tumble Drier (T75370AH) that I have already taken apart in the past because the belt snapped, but which has now developed yet another fault: Water is no longer collecting the water receptacle which slides open like a drawer at the same height as the control display.
My first line of attack was to replace the Drain Pump which can be accessed via the back of the drier with a dedicated access behind some screws and panel that reads something about Fluron gas. Once I changed the pump and started the machine I was able to hear the pump working and it should have then started sucking up the water that I put in the back compartment. This did not happen.
Logically my next thing to test was whether o not the tubes were blocked (there is a red tube that goes from the pump fitting up to the water collection receptacle while there is also a clear tube running down from the receptacle in case the water collection case becomes full and over-flows. I removed the tubes and checked them for to see if there were any blocks in the tubes, but there were not any.
So that is where I am at.
If I run a drying cycle it will run until such time as the safety mechanism cuts out - IE I get a light on the front of the machine indicating to me that the water container needs emptying but it is, obviously, empty. If I run a full cycle, all the water remains in the bottom of the drier and it leaks out of the front of the at the bottom where the condenser filter is.
I have also removed the back panel and cleaned out the inside of the Drier and also pulled the front bottom panel off and cleaned the condenser filter (which this model has such that it is basically impossible to remove).
What on earth is there left to do, I am completely stumped. I am lucky as I have a shop very close by that sells all the technical spares for this model. I am already £50 down for the drain pump (original).
Thanks.
Gillliam
https://manualzz.com/doc/50641822/aeg-t75370ah-manuale-utente
Thanks.
Gillliam
