Aging Huebsch
huebschman
Apr 18, 2010
87
Quebec, CA
The plastic side and aluminum front panels of my 2009 Huebsch ZWN432 (and matching dryer) consoles has yellowed over time. Do anyone have a magic trick to get them whiter (bleach doesn't work) ???
... Other than changing the parts of course.
Thanks!
Thanks Jamie!!!
Why I haven't thought of this is beyond me... And I dye my hair!!!
Did a spot check and got some result. So I set up a small station on top of dryer and brushed the stuff over the surfaces (used 3% / 10 Vol. hydrogen peroxide cream) over a few days. Did not bother with the plastic wrap (too much hassle) and applied whenever I came around to it (every 8 to 12 hours).
After 8 applications, I got the desired result. It is not enamel white but good enough for me.
Will buy the stronger stuff (peroxide) to maintain every now and then. Thanks again.
P.S.: Did wonders on the extra rince button also :)
Forgot to mention... Gave the panel a wipe with a wet rag after (what I decided would be) the final application.
Lots of yellow on that rag. Did not wipe in between applications. FYI.
