Agitator re-manufacturers
Oh that’s unique looking, I
So does anybody know what my best options would be? On how to get a ramped agitator that fits, is it as simple as making an adapter collar that fits that machine or do I need to 3-D print the entire agitator instead?
If you are OK with the wider base where it sits at the bottom of the tub, then using an original agitator with the hexagonal adapter would be far far far cheaper and easier.
Yeah that’s true, I’ve just gotta make sure that there’s
Enough clearance from The enamel as I don’t want to mark it and create a ring where the agitator rubs, either that or here’s an idea, I could potentially try to get the agitator shaved down on the bottom so that way it’s short enough that it can easily rest on the original Shaft
