murando531
Our Lowe's finally has this set on the floor. In person it's alot less impressive. It seems to have a huge capacity, but just as my Bravos is large, I know that the water level will be only about 20% of that tub at most. I was disappointed at the build quality of the lid on the washer and also the dryer door. Both have that squeaky plastic sound when opened and closed. I wonder if the see through material is acrylic instead of glass, because it doesn't feel heavy or solid at all. The dryer door actually bends and wobbles when you try to close it. I hate the dispenser drawer as well. Seems like more trouble than the built in dispensers around the opening, not to mention how flimsy the drawer is.
Apparently the washer was in its "agitate" mode when shut down and boxed up, and I could tell it's a similar drive system to what LG, and by extension, Samsung, have been using in their impeller style washers for a while. I turned the basket and the impeller would rotate at a slower but set rate, just as the LG will. I reached down and manually turned the impeller and you could hear and feel the gears that are now in place. I wonder why they decided that the Cabrio now needs a gearbox? And why does this machine sound so loud in comparison to the F&P drive version if it's supposed to be the TOL right now?
