All this Westy talk got me thinking...
Check if door switch is working
WOW; many nice images of a rebuild!
Here with 1976 westy pairs the lower panels repainting on one had a tiny piece of paint foul the door switch; even when it was masked twice. Thus on the washer I bought a new door switch.
In the usa the westy dryers I have messed with have a 120 volt ac motor and timer too is wired so it connects to 120 volts. ie one hot leg and the neutral wire which is at ground or real close to ground in voltage with usa house wiring. The heater coil is 240 volts on most all and can be wired for 240 volts or just 120 volts for a old house too. There were some super old mid 1940's westy dryers that were for 120 volts only too; ie could not be wired for 240 volts. That is one I grew up with, my dad got it when he lived in an old apartment in the 1940's that was 120 volts only. It was not just a 240 volt unit wired for 120; it was a 120 volt unit only with a weird 120 volt coil and factory 120 volt cord and no switcher roo lugs for using 240 volts.
Dryers are most simple, door switches, thermostat, heater coil etc. Check for a bad joint/connection
SLANT FRONT WESTIES
WOW Paul they look great you make me tired just reading your posts LOL. It is very easy to attach a 120 volt cord to this dryer and everything should run fine, in fact this dryer was designed to run on 120 volts if need be. There was an extensive thread on this topic a while ago if you can't find it call me and I can easily explain it [ we don't want any more electrical black outs in that area of Canada again LOL ] John.
Love how you always put in the "BUTS" and the hubby&
you say TOUGH!!! Good for you. These are the signature quintessential iconic Westinghouses of many of our childhood days. They look amazing. Your patience and skill are enviable. Wish I had them.
Gotta a kick out of the Westinghouse paint "fire' in #6
Paul, what is the GE like machine off in the back in the back in Reply #1? Very Interesting.
All your kind words got me calmed down enough to think clearly about what went wrong with the dryer and I am now convinced that when I redid the connector on the door switch I made a bad connection on one of those 'spade' disconnect termials.  AND I looked at some of the photos I took when I first attacked it in 2010 and I think I know what I did wrong with the lint trap rod...  It'll be the week after next though before I can get to them... If I have any spare moments next weekend, there's a 58 Frigidaire dishwasher that needs to be re-assembled... LOL
About the paint job - I learned during the L5 restoration that I have no talent when using a spray can... SO, I started messing around with appliance epoxy (I use the Rust-Oleum brand from Home Depot) and a foam roller. It works really well!  You just need to rough up the finish a wee bit with sandpaper and clean off the dust to prepare the surface and you're ready to paint.  I put two coats on the Westy set to make them nice and smooth!
These were indeed made in Canada - in Hamilton Ontario to be exact!   Great story behind this set that I think I will have do a little movie about...  Stay tuned!
The chrome was slightly pitted on both the washer and dryer, but I used some very fine steel wool to take down the lumps.  The finish is not 'like new' to be sure, but it sure polished up nicely!  John (combo52) gave me that tip!!
Micheal - that's a 1958 GE clothes conditioner dryer.  It has the 'synthetic suit de-wrinkler' button on it that cracks me up thinking about how it would work in a cartoon... LOL
Darren - I have set up a guest bed in the basement with your name on it!
Much time as I spent behind a Westy of that era, can't remember for sure if it had 2 belts (both to motor) or 3 and an intermediate idler like the 'potato' models. Chance you have a nice flash pic of the rear mechanics?
2 belt speed changer images are on other current thread
There are some image of the older 2 belt system with speed changer gizmo here on this other thread:
Nice work! The machines look awesome and well done! I think these are some of my most favorite FLs even though I am a TL kinda guy. Now I understand why you were so busy lol.
Yes, we had the 'speed changer' one too, aprx 1947.
Its replacement had no gearbox, but the 'mushroom' variable spin pulley. What I can't remember is whether it had a tumble idler or not. I don't think it did, but as before, 1800rpm to tumble speed in one reduction seems a lot.
Apparent, that the innards changed more at times than the cabinet.
EARLY WH FL WASHERS
WH had three different drive systems inn thier slant front washers. The first with the speed changer had just two belts the next two designs had three belts and these both had an idler pulley. All of these used a 1/3 HP 1725 RPM non reversing motor.
also....
...the motors on the machines that had speed changer units had a "High Torque" winding during the first 60 seconds of spin, then it went back to the regular Run winding- I was wondering if anyone that has replaced a motor on these machines were able to use a newer style motor with out the "High Torque" on it-( the newer styles had only three terminals, not four)  I am not sure how I am interpeting the schematic, but it looks like an extra length in series with the run winding...
[this post was last edited: 5/18/2011-11:28]
