Alternative to Replacing Laundry Box Faucets
philcobendixduo
Mar 16, 2010
535
San Jose
My Oatey laundry box was installed in 1992 and has the "old fashioned" gate valve shut-offs.
Because I have braided stainless hoses connecting the faucets to my washer, I never have turned off the valves.
Consequently, the valves are "corroded" in an open position and, in my experience, gate valves will fail to stop the water flow when closed when they are old like these are.
I will soon have to replace my 1987 Kenmore washer with new machine and the only way I'll be able to turn off the water to the machine is to turn off the whole house water supply.
To replace the faucets will entail opening up the wall to unsolder the connections to the copper pipes and I don't want to go there.
I am thinking that maybe I can just buy two hose shut-offs (like those used for outdoor garden hoses), screw them on to the existing laundry faucets, and then I'll have two new shut-offs.
I would need to find brass shut-offs that can withstand hot water.
Has anyone done something like this with their washing machine setups?
I know a lot of you have multiple machines that are all connected to water etc.
Do you have a shut-off valve that screws on to a hose bib that you'd recommend?
Thanks for the help!
I’ve had brass shutoff valves on the faucets for my washer for over 10 years now and they work great. Since the washer is upstairs and a leaking valve, hose or a failed shutoff valve in the washer could cause great damage I turn the water off every time I’m finished doing the laundry and turn it back on to use the washer,
I bought these valves in the garden department of Home Depot. They are quarter turn valves and they say to not use with water over 140 degrees. Our water heater is set at 130 F and we’ve never had a problem with them. I got the idea from a old member Martin (yogitunes) in New Jersey at his suggestion.
Eddie
    1.9 MB
