An Interesting Test with a New Meter
Hi Mark, wow 24 gallons for 5lbs of towels that is a shocking amount of water used, considering I can wash nearly 10lbs of towels in 28 gallons in the Unimatic.
Yes my big bath sheet towels are 100% cotton although they are a few years old so they aren't as fluffy as they were when they were new and certainly don't produce as much lint as when they were new.
I checked your math and you're right on, but it seems like more water should have been removed. It is shockingly bad actually as the 525rpm Kenmore came in just over 70%. Does your Siemens (Bosch) spin at 1200rpm for long or does it slowly ramp up and then only spin at high speed for a minute or two?
It was indeed a lot of water for such a small load. But I did select the "water plus" option (or whatever Siemens calls it) which could explain it. I could try a load of towels without that option. If I washed double the amount of towels, it would be interesting to see by how much the water usage would change.
My towels are 100% cotton and are a few years old. Fieldcrest from Target.
It did spin at full speed for a few minutes but probably not nearly as long as it would have done on the cotton cycle or eco cycle (I used the "mix" cycle). I'll have to test that. I have the exact same towels in the US and I'll have to try this test when I'm back there. I think I weighed these towels a couple of years ago after being spun in one of my TLs (I can't remember which, possibly the SQ at 710 RPM) and I think the RMC was over 100%.
It would be very interesting if anyone else could weigh a towel when dry and also after spinning and let us know the weights.
I really do wonder if you’ll get that many suds from things that were washed in a front loader (HE in general), then re-washing them in a Frigidaire Unimatic 🤔
Update!
I like the tests and measurements that Robert has done with his LG and his snazzy new Samsung (congrats, by the way!). And I've done a few more of my own.
Following on from my post above, I've tried washing a full load of towels on several cycles. The towels weighed a fraction under 5 kg or 11 lb. I had to cram the towels into the drum but once they were wet, they sank down a lot and there was plenty of space to tumble.
Cottons 60 ℃ (140 ℉) with no options selected:
Wash used 24 litres / 6⅓ US gallons
Three rinses
Total water usage: 100 litres / 26½ gal
3 hours 37 min
1.78 kWh
Eco 40-60 (this is the machine's most efficient cycle and is used for the energy rating):
Wash used 22 litres / 6 gal
Three rinses (first two used less water, probably due to very short, slow spin after the wash and first rinse. Final rinse used 26.5 litres / 7 gal
Total water usage: 74 litres / 19½ gal
3 hours 40 min
0.86 kWh
Cottons 90 ℃ (194 ℉) with Water Plus selected:
Wash used 23 litres / 6 gal and did a cool down before draining, adding a further 14 litres / 3.7 gal for a total of 37 litres / 10 gal in the tub
Four rinses, each consuming 28.5 litres / 7½ gal
Total water usage: 150 litres / 40 gal
3 hours 17 min
2.57 kWh
This machine has a 1,200-RPM spin and top speed was held for 5 min on the cottons cycle. But the Eco cycle speeded up for the last 2 minutes, seemingly faster than 1,200 RPM.
After the Eco cycle, the towels weighed 8.4 kg (18 lb 8 oz).
So the towels retained 8.4-5 = 3.4 kg or 3.4 litres of water (7 lb 8 oz)
Remaining moisture content: 3.4/5 x 100 = 68%
Hi Mark, now isn't that interesting! Two things stand out to me, the large amount of water consumption and after extraction there was 68% of water retention. That seems odd considering a 525rpm belt-drive Kenmore left 71% of water retention.
A few quick questions for clarity:
How big is the drum in your Siemens?
How many towels did you put in there to reach 11lbs?
For reference how many of those towels could fit in your Unimatic for a full load that still turns over (that's if your in Palm Springs to check that of course, although looking at your images makes me think your doing the test in Madrid)?
Hi Mark, now isn't that interesting! Two things stand out to me, the large amount of water consumption and after extraction there was 68% of water retention. That seems odd considering a 525rpm belt-drive Kenmore removed left 71% of water retention.
I think it has to do with wide and shallow tubs vs tubs that are deeper and narrower. The g-forces are multiplied quite a bit in tubs that are wider and shallow vs the deeper and narrower tubs on some machines,
The engineers who were tasked when designing the machines of the past wanted to extract as much water out while not using lots and lots of power to do, as a result tubs were shallow but wide forcing more water out.
When I used my grandmother’s Whirlpool VMW back in 2019, the clothes felt like they were spun out in my Maytag, took about 40 minutes to dry which is about the same amount of time my Maytag dryer takes to dry an average load.
