classicguywi
Hello all,
I figured I would post an update on my a906, replaced the fill valve after looking into it and figuring out that the cold side was indeed stuck open. However after replacing the fill valve I gave her a try only to find out that the timer was not advancing, and even when it had reached the point of being full it was still calling for water.
I could hear the timer motor running though.
so I guess my question is:
That the water level switch is what tells the timer that the tub is full and to advance to start the cycle, and if something in this cycle of checks was not working correctly ( level switch ) then the system would not advance and continue to call to fill the tub ?
Mike
Mike
