I have also been lurking here for nearly a year. Started studying washers mostly due to the fact that my BOL 2010 Admiral top loader and dryer were doing a fine job of cleaning my clothes, but had some serious drawbacks:
1. The water usage of the top loader was an issue here in the Desert Southwest.
2. Clothing wear was noticeable with the BOL pair. I own a first generation WP Duet "elsewhere" and was okay with it and managed to kill the mold smell with bleach once a week.
Really, the Admiral set was a temporary pair bought on the cheap for a temporary situation. With a more permanent presence here, I decided it was time to take the plunge.
I also searched long and hard for the proper washing machinery for my home. I'm not an engineer, but I do know a lot about turning wrenches and screw drivers. I was familiar with both the benefits and drawbacks of the consumer grade front loaders vs tops. Long story short, I ended up with a non-matching set that I love, and I must thank the regular contributors around here for their insight.
I leveraged a friendly connection with a Unimac dealer. I bought a FTUA1AWN1102 and a "base" (they don't call it a pedestal even if it does the same thing) for dealer cost.
I wanted a dryer with a moisture sensor, having experience with these in the past, so I went with a Maytag MGDB850YG from Whirlpool Outlet. I thought it was a good deal at $637 delivered.
The review...
The washer is simple. WAY simple. My old 2003 vintage Duet would sense and play around, maybe decide take an hour. On the other hand, this Unimac washes quick and doesn't fool around. Thanks to an error by the dealer's delivery guys, the washer wasn't properly attached to the base. (If any of you are considering this setup and get involved with the commercial "bases" keep in mind the legs of the washer stay on when you put it on a base.) Found this out the hard way, the machine decided to really shake and rock, also took a walk... No problem though, the dealer fixed it without even a hint of complaint. Now it's rock solid and it does a fine job of washing clothes without tearing them apart. Hardly any lint ends up in the dryer, which is a testament to how gently it treats things. I also appreciate the ease in which I can get to the pump motor and the debris trap by simply removing two screws. The clothes for the most part come out clean, better than the old tops where despite all the water used most grease stains would slip right through unless heavily pretreated. For white, sometimes I will wash and then do a manual soak by moving the dial to off. This might be my only complaint about the whole appliance -- I would be interested in adjusting the wash agitation longer for a whites load without manual interference. I do laundry the old fashioned way, I sort, I pretreat what is obvious, I wash.
This washer does have one interesting feature I haven't used yet: connections and ports for supply injection. Anyone have ideas on utilizing this feature?
The dryer is a Bravos XL series closeout. It is a steam model. This feature I have hooked up and used a total of once. I don't think I really care for the steam cycle and might not use it again. Everything else is cool about it, and I appreciate that this thing doesn't dry my clothes to a crispy, shrunken end. Other than that, it's a simple and solid seeming dryer. Aside from the controls and cabinet, the drum itself seems very familiar -- like the one on the 2003 era Duet. The electronic controls are a contrast to the industrial Unimac, but for what I paid for this thing, I think I did okay.
Based upon my experience with the Alliance product, I placed an order for 8 (!!!) ATE50 s for rental units. That wasn't cheap, but you should hear how happy the tenants are that the old Kenmore badged Frigidaire/Electrolux stacked top loaders are gone. I'm thinking long term here, mostly that when something would go bad with the Frigidaires, we would be scrambling to find parts and when we could, they were expensive and a pain to fix. Yes, this decision was made after I opened up the bottom cabinet on the Unimac.
As for me, I'm hooked. This front loader, regardless of the capacity numbers everyone throws around, handles darn near double the amount of laundry the old top loader did, because the top would really get nasty about wringing clothes and tearing things up if you actually filled it.
The review...
